Hotpoint WD860
  • #55137
    gasman999
    Help please we have a WD860 washer drier that has a f 13 error code what does it mean.
    #322034
    helo_75
    its not sensing the dryer thermistor
    #322035
    gasman999
    Re: Hotpoint WD860
    Thankyou for the information, where in the machine is the thermister located.
    #322036
    helo_75
    on the top, on the silver duct, its a small black disc type thing, held on with 2 screws
    #322037
    simonpj145
    Re: Hotpoint WD860 – please help!!
    Hi there. Hoping To get some quick advice on this. My problem is the dryer not working.
    I am a novice with a multimeter but have confirmed the following:
    Thermistor indicates open circuit on a continuity check but on a resistance test indicates about 17kohms. Does this make sense and if so is the thermistor ok? I read somewhere that the reading should be about 24kohms.
    The heating coil looks dead, it is dark in the middle and has splits. However I do have continuity and very little resistance. Presumably this means the element is fine even though it looks rough. Wuld you suggest changing to prolong life or not really?
    Finally I cannot locate the thermostat or TOC there don’t seem to be any other devices on the unit other than the fan motor,which shows low resistance and a small degree of continuity.
    I hope this makes sense. Does this indicate the problem or do I need to look elsewhere? By the way, the problem is the dryer not drying!
    Many thanks
    #322038
    Hotpoint WD860
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain the element is faulty. The toc is inside the yellow sheathed cabling.
    #322039
    simonpj145
    Re: Hotpoint WD860
    Magic, thank you very much. Simon
