Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WD860 Door Glass Scratched
- This topic has 3 replies, 3 voices, and was last updated 20 years, 2 months ago by
oldfield_ian.
January 22, 2006 at 11:25 pm #15048
oldfield_ian
ParticipantHi. We purchased a Hotpoint WD860 in October 2005. Since then we have had the door replaced twice due to scratches on the glass from the drum. On the first instance these were quite substantial. Now, two doors on we have the same problem – scratched glass door – despite very careful attention to a balanced load and low spin speed.
The engineer suggested the machine should not be used at 1600!! I guess he would not write a statement to that effect (and presumably lose his job).
Has anyone else experienced a similar fault with this machine?
Regards
Ian.
January 22, 2006 at 11:38 pm #161843iadom
ModeratorRe: Hotpoint WD860 Door Glass Scratched
It is something that we have seen on around 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of Hotpoint machines over the last thirty years, and to a greater or lesser degree on all others depending on the make and model. My own 1600 spin WMA62 has many scratches on the door. My wife just bangs the machine on and lets it get on with it, however when I do the washing I always reduce the spin speed down to around 1100 rpm or even lower. The amount of water you will extract at 1600 rpm as opposed to 1100 rpm is miniscule, the downside of the very fast spin is severe wear and tear, excessive noise, scratched doors etc.
It does not have any effect on the machine and is purely a cosmetic problem.PS. I cannot tell the wife how to use the machine for fear of the, ‘deaf & dumb breakfast’ syndrome. 😆
January 23, 2006 at 9:07 am #161844Martin
ParticipantRe: Hotpoint WD860 Door Glass Scratched
oldfield_ian wrote:The engineer suggested the machine should not be used at 1600!! I guess he would not write a statement to that effect (and presumably lose his job)
Whilst you can still enjoy the benefit of the manufacturers guarantee, I would call them in to replace the damaged part yet again. Whilst Hotpoint machines do have this apparent design weakness, I would also suggest you do not accept the status quo.
If reducing the spin speed is the only true answer to the problem (as the Hotpoint engineer suggests) then I would claim your machine is not fit for the purpose for which it was designed.
A free replacement machine might be the only acceptable answer perhaps?
January 23, 2006 at 11:41 am #161845iadom
To be honest, the old Hotpoint 1850 range used to cut right through the plastic door ‘glass’ fairly often, and they only spun at 1000 max. More to do with design of door, drum and suspension.
