Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD860 Dryer no heat
- This topic has 19 replies, 6 voices, and was last updated 19 years, 1 month ago by
Bernie.
February 21, 2007 at 2:08 pm #25241
Bernie
ParticipantI have just been to a WD860 for a, no dryer heat, fault.
Have checked the heater/stat/one shot all have continuity, checked loom not rubbing onto weight all ok. Fan runs ok but no supply to heater.
Have read the link: –http://www.ukwhitegoods.co.uk/modules.p … ight=wd420
But this has not given me any more ideas, could it be the Board?
Can anyone help please?
BernieFebruary 21, 2007 at 3:03 pm #205048Bernie
ParticipantRe: Hotpoint WD860 Dryer no heat
Does anybody know the part number for the service manual for this machine?
Have tried Connections but there answer was ‘you need to contact Merloni/Hotpoint direct’Bernie
February 21, 2007 at 3:11 pm #205049iadom
ModeratorRe: Hotpoint WD860 Dryer no heat
Board is a possible, relays can stick. I would be pointing this customer back to Hotpoint, the boards are very expensive, also six different eeproms from what I can see. Difficult call, buy an expensive module that isn’t the cause and you are out of pocket, or give the customer a bill for £150 inc labour if it is faulty:cry:
You should be getting F14 or F15 in display. F15 is more likely to be relay.
February 21, 2007 at 3:44 pm #205050iadom
Bernie wrote:Does anybody know the part number for the service manual for this machine?
5407171. 🙂
February 21, 2007 at 5:06 pm #205051DAR01
Have you checked the in line thermal cut out? (microtemp)
MIKE
February 21, 2007 at 8:39 pm #205052iadom
DAR01 wrote:Have you checked the in line thermal cut out? (microtemp)
MIKE
Only fitted after May 2006.
February 22, 2007 at 8:50 am #205053Bernie
Many thanks to all of you for you help
Bernie
March 7, 2007 at 8:18 pm #205054Bernie
The problem with this was the wire to the heater was broken at the amp tag still looking like it was all connected.
It wasn’t until I was checked the continuity of the wires to the PCB that I found this one.Thanks again for the help
Bernie
March 29, 2007 at 3:30 pm #205055admin
KeymasterRe: Hotpoint WD860 Dryer no heat
Sorry to reopen this one but I went to a wd420 a month or so ago and changed the one shot…….everything else seemed fine…no fluff filter fitted etc…but just got a call for same thing….also got a wd860 to go to tomorrow so am totally confused what to do…..
Can someone sum up the current fix please!!!!!!!
ColMarch 29, 2007 at 3:38 pm #205056hotpnt
only the dryer fan may be loose, or the fixing spinning within the fan
March 29, 2007 at 3:43 pm #205057admin
Also in some of the earlier posts it mentions changing the heater to new sort……what was the old sort like?……one fitted is spiral type……is there any more info on the newer heater box…is it basically the original one without fluff filter…..
cheers colMarch 29, 2007 at 4:04 pm #205058hotpnt
there have been 3 heater boxes,
March 29, 2007 at 4:27 pm #205059Martin114
Pity they didnt just replace the one shot with a thermal fuse in the first place. :rolls:
March 29, 2007 at 4:36 pm #205060admin
So can I convert to use a thermal fuse instead then ? got one part no. C00080775 on van……do you know the temp of the fuse?
Thanks for help…col
March 29, 2007 at 4:41 pm #205061hotpnt
well that’t be up to you, the part for the thermal cut-out is the same as the indesit one (c00080775) hovever there would be no clamp for it, plus i do not know if the heat box would be the same thickness (to ensure the excess heat can fuse the link if it needs to)
