Hotpoint WD860 F-01 fault – help needed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD860 F-01 fault – help needed
  • #85962
    hughwatkins
    I’d really like some advice. I have a Hotpoint WD860 with a F-01 fault.
    The machine turns on fine, you can select a program. Then as soon as the program starts the pump kicks in and it flashes END and then F-01. The pump remains ON. And you can’t turn the machine off extra by the plug.
    Any ideas of what could be wrong and whether I can replace the part?
    Thanks a lot.
    Hugh
    #429899
    Re: Hotpoint WD860 F-01 fault – help needed
    hughwatkins wrote: whether I can replace the part?
    The part that needs replacing is likely to be the whole machine. 🙁
    F01 is supposed to be a faulty motor triac, a component on the main pcb.
    If you are very, very lucky it could be loose or broken motor wiring plug connections.
    If not then the pcb will need changing, a new pcb will also need programming as well.
    #429900
    hughwatkins
    Thanks.
    Is that the pcb which controls the front panel including switches?
    Or is it the main board?
    The main board looks double the price and a bit harder to replace! Given the machine is 9yrs old.
    Hugh
    #429901
    The main board, around £100 but needs a £20 smart card and a £103 card reader to program.
    You could always send the board off to EMW. 😉
    #429902
    hughwatkins
    Thanks. It’s nine years old so I think I’ll invest in a new one this time!
