Hotpoint WD860 stops on 1 minute remaining
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD860 stops on 1 minute remaining
  • #74259
    hughwatkins
    I’ve got a Hotpoint WD860 washing machine. On all cycles it runs fine, then stops on 1 min for ever. You have to cancel the cycle then rinse & spin.
    Any ideas what the fault could be? No lights or warning messages.
    Hugh
    #390608
    Re: Hotpoint WD860 stops on 1 minute remaining
    Sadly there is no specific answer to your question, the Indesit electronics in this machine are very flaky at the best of times.
    It could be just about anything from faulty pressure switch, drain pump, main pcb, dryer ntc, bad insulation etc, etc.
    It can be a nightmare to isolate the cause and an expensive one at that. 😥
    #390609
    scientist
    Whats the water pressure like? Had this on a hotpoint recently and this is what the fault was! Best of luck 🙂
    #390610
    karv
    Have you checked the waste pipe is not to far down the down pipe if you have one .
    I had a element causing problems once can,t recall if was open circuit or low insulation.
    #390611
    You will see from the last two posts that there is no definitive answer to your question, only three or four more possibilities. 😥
