Hotpoint WD860 – test message
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD860 – test message
  • #24680
    alexb
    When trying to select any wash programme on our Hotpoint WD860, the programme fails to start.
    Instead the display reads as ‘test’, and the machine seems to run through each of the five options, dry, spin, rinse, wash, prewash over about an 8 minute period.
    When left, the machine will repeatedly run through this test programme.
    Any advice would be greatly appreciated.
    Many Thanks.
    Alex.
    #202962
    Re: Hotpoint WD860 – test message
    Using the forum search would bring up many answers such as this one.
    http://tinyurl.com/24mdjk
    if that doesn’t work then post up your machines date code ( the first two numbers of the serial number) there are a few variations to clear test, this ‘fault’ is usually caused by someone pressing On/Off & Start button at the same time.
    alexb
    Thanks for the reply Jim.
    I pressed and held the 2 buttons On/Off and Start/Cancel until it showed the message ‘dOff’
    It now seems to be working OK!
    #202964
    No problem, thanks for getting back to us with the outcome.
