Hotpoint WD860P F-03
Viewing 1 post (of 1 total)
  • #43743
    F-03 flashing and continuous fill/drain.
    I have measured the resistance of the thermistors at room temp – Washer Thermistor 41 KOhm, Dryer Thermistor 27KOhm.
    Is it a thermistor problem or the main PCB?
    If it is the main PCB is it worth getting a replacement as it appears from this forum I am likely to have more problems with this machine soon?
    If I do replace the PCB where/how do I get the correct one. I have got hold of a second hand one but connector J10 is different. I assume there are other small differences on the board.
    Thanks.
