F-03 flashing and continuous fill/drain.
I have measured the resistance of the thermistors at room temp – Washer thermistor 41 KOhm, Dryer thermistor 27 KOhm.
Is it likely to be a thermistor fault or the main PCB?
If it is the main PCB is it worth replacing it as posts on this forum suggest I am likely to have more problems with this machine soon?
If I replace the PCB how/where will I get the correct one? I have already got hold of a secondhand one but the J10 connector is different and therefore I assume there are other differences on the board.
