Hotpoint wd860p sn 54090110
Help. Is anyone able to send me a wiring diagram for this machine. It’s driving me crazy. Ewm have tested the board,, I have fitted a new motor and still get f01 error code. I have checked all the connectors but I’m beginning to doubt myself on the connections to the power module
I,ve found F01 faults are normaly the motor harness or the module, the motors dont give any bother normaly, have you checked the motor plug for signs of water ingress this will give F01 fault also.
Had one giving an F01 fault checked harness with a circuit tester so decided it must be module fitted that only for it still to be there, changed harness bingo cured can only assume i was getting circuit becaues i moved it and when i reffited the break opened again.
