Hotpoint WDAL 9640 washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WDAL 9640 washer dryer
  • #100415
    chuffy
    I’ve been called out to two of these machines recently because they were very noisy.
    On inspection I found that the sub frame was cracked where the suspension unit/damper is attached which was causing the noise.
    Certainly seems like a design fault because the sub frame metal is quite thin and I’m wondering if perhaps Hotpoint have brought out a repair kit to rectify this issue?
    I’ve managed to effect a repair by fabricating a steel plate to sit between the sub frame and damper to spread the load.
    #480527
    not an unusual problem
    new shocks do have a plate but does not really cure bad existing cracks
    https://shop.ukwhitegoods.co.uk/c00140744-washing-machine-suspension-damper-kit
    murv
    The Aqualtis repair kit may do the job. Part No. C00535888 – Picture available on Connect
    Murv…
    #480529
    chuffy
    Many thanks guys.
    The suspension kit with the plates is the way to go.
    Cheers.
