Hotpoint WDD960
  • #64876
    clivejameson
    Having trouble finding the correct inlet valve for this one…the original seems to have an extension to the incoming side but the replacements don’t which means the valve doesn’t reach the back panel for mounting correctly. The extension is bonded on (or not which is why it was leaking!)…has anyone else come accross this or got a part number for the correct valave please?
    #358354
    DDSDDS
    Re: Hotpoint WDD960
    seem to remember something similar and needed a new dispensor assembly too
    #358355
    Re: Hotpoint WDD960
    The valve comes as part of the dispenser assy (C00269609) which may be shorter than the original and in order to link the hose to the valve you’ll also need a ‘Valve Mounting Plate'(C001199371)
    HTH? 😀
    #358356
    clivejameson
    Re: Hotpoint WDD960
    Cheers for that Martin…i suspect there’s too many ‘1’s in that last number and that throws up the plastic support panel for the valves at the back but going on description i’ve ordered the VMPlate from connect so we’ll see what arrives.
    Thanks again.
