hotpoint wdd960 f13
  • #52403
    funbobby
    changed element on this as open circuit but customer said after half hour or so on drying flashed up f13. any ideas before i go back?
    #311649
    BobHope
    Re: hotpoint wdd960 f13
    blocked flushing filter. or faulty dryer NTC.
    Bob.
    #311650
    suedehead1
    thought i would use an old post,
    i have got the same problem F13 changed the thermistor and checked the wiring thoroughly.
    the dryer runs for 10 minutes then the fan motor and heater cut off
    then F13 comes up.
    spoke to tony at emw who said it wasnt a pcb fault,
    any ideas welcome.
    #311651
    Whenever I do any repairs on the dryer side on these I always remove the small filter at the back and cut out the gauze mesh then refit to allow a decent airflow.
    #311652
    suedehead1
    thanks didnt think about that its only just over a year old
    and is not used much but i will give it a try.
    thanks.
    #311653
    suedehead1
    there was no mesh on this one its quite a new machine,
    ran it with the door open and got a good flow of air through it
    but fan motor keeps cutting out and still showing F13.
