HOTPOINT WDD960 – SPINNING WHILST DRYING
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HOTPOINT WDD960 – SPINNING WHILST DRYING
  • #41971
    lexy
    I have a new Hotpoint WDD960 washer dryer. I have just noticed that when doing a cotton wash dry cycle, the unit does a high speed spin during the drying cycle – leaving the clothes stuck to the side of the drum. Does anyone know whether this is normal behaviour or a fault?
    Many thanks,
    Alex
    #271881
    stripey
    Re: HOTPOINT WDD960 – SPINNING WHILST DRYING
    Hi the machine is designed to do a “thermal spin” after about 20 mins. I believe that if you look in the handbook it does mention this.
    #271882
    stripey wrote:I believe that if you look in the handbook it does mention this.
    No it doesn’t…new one on me????? 😕 Why does it do that then?
    #271883
    lexy
    I’ve had a good look at the manual and can’t find any reference to a “thermal spin” anywhere in it!
    #271884
    BobHope
    hi all,
    your appliance does do a 5 minute thermal spin when the drying load temp reaches 50 C this normal and it should be in your handbook.
    Bob.
    #271885
    Been on the machines for years.
    Even the old WD’s with the hybrid timer had it on later models, and if you ever had to fit a new timer or a control module to one of that model range the timer came with a leaflet to leave with the customer informing them of the spin during drying feature.
    It isn’t in the manual though, just checked. In fact I believe the Indesit Company won some sort of award from somebody for the spin on dry feature on their machines, even though it was used on Hotpoint and others earlier.
    lexy
    What’s it supposed to achieve then? All it seems to do is to stick the clothes to the outside of the drum so that they don’t dry at all!
    #271887
    helo_75
    Thermal Spin
    A thermal spin on the High Heat setting is carried at the start of the of the drying process. The load is
    pre-heated to approximately 50°C by the dryer heater with normal tumble action and pump out. The
    thermistor located in the wash heater will sense the load temperature and when 50°C is achieved a 5
    minute Spin profile will be carried out at full spin speed.
    During thermal spin the out of Balance detection will operate and maximum speed will only be
    achieved depending on the out of balance condition.
    On completion of the Thermal Spin, the tumble drying process will commence for the period of time
    selected.
    Thermal spin is NOT available when low heat is selected.
    thats from the manual.. but still it doesnt say why
    hmm
    #271888
    lexy
    Thanks for the input guys. Just wish it had said that in MY manual!
    #271889
    Washman
    Some of the Servis Washer Dryers do it as well after about 8 mins.
    Mike
