Hotpoint WDd960 wiring help
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WDd960 wiring help
  • #89035
    Shudavcalledapro
    Hi all
    Right, I’m having a run of bad luck with this machine. Due to an error code I got an exchange control module board. Got the old one out easy enough. When putting the replacement in I hadn’t realised I had loosened one of the connector plugs cable grip…….next thing I have 5 loose cables with no idea which one goes to which pin on the connector!!
    The board in question is a Delta electronics EADP-C002-1. One edge of this board has only two connectors. One with 5 red cables and one with 5 blue. It is the red cables I am in trouble with.
    I am guessing (and it is a guess) that these cables link to the control panel buttons on the face of the machine??
    No real idea how to start tracing this.
    Can anyone help?
    Cheers
    #440133
    Re: Hotpoint WDd960 wiring help
    Single colour wires on a connector block usually share the exact same connections at the other end of the loom.
    #440134
    Shudavcalledapro
    Thanks, you were spot on. Got nachine powered back up.
    Bad news is even with the new control module I still get the F15 error code!!!
    A lot of work to get nowhere fast.
    Anyone got any suggestions on what to check next? Before buying the replacement board I had the pressure switch out and blowing into it I get a reassuring click so that seems to be working.
    Any help appreciated.
    #440135
    Shudavcalledapro
    Quick update.
    The F15 code comes up and all 5 led’s are flashing rapidly and so is the led on the start/pause button.
    If I put the machine on a spin only cycle it stops with the above error code shortly (within a few seconds) after pumpin out. If I put it on a long hot wash it will wash for about an hour before stopping with the same error.
    Searching the net suggests the error relates to the heater relay (which I was lead to believe
    Is on the main pcb, hence why I changed it). I have however not found an exact match for the error code and lit LED’s combination,
    Anyone seen this before?
