Hotpoint WDF740 nightmare call
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WDF740 nightmare call
  • #65675
    cornwell40
    1st call to this was a leaking valve. Dryer solenoid had overheated and distorted the valve casing. Ordered 3 way valve to find it wasn’t long enough, the old extender was bonded on, so had to concoct something with a hose entering the valve cover via the v hose. All test fine.
    They then complained of the clothes coming out hot and very wet at the end of the cyclewhich hadn’t happened before. No restrictor fitted for the dry valve, back to fit one….test ok.
    Still doing same thing 👿 , clear out the filter in the heater box.
    Apparently after all that it’s still doing the same thing. Clothes coming out very hot and wetter than they went in.
    Any more ideas :con:
    Tony
    #361516
    A1engineer
    Re: Hotpoint WDF740 nightmare call
    blocked sump??
    #361517
    Which version of WDF740 is it anyway? (Full model number) Split or welded drum?
    #361518
    cornwell40
    Tis a split drum. Checked the sump btw 🙁
    T
    #361519
    cornwell40
    Founda piece of polythene wrapping lodged in the pressure chamber 😀 on a subsequent call. Now the clothes just come out wet not hot anymore 🙁 .
    I hate this machine now 👿
    Tony
    #361520
    cornwell40
    Does anyone know the correct part number for the 3 way fill valve on this machine. Numbers are 80 9150145 //54737
    Also can the valve flow restrictors be bought separately anywhere. Have checked and double checked everything on this machine but can find nothing else to cause the fault. Got them to put dry towels in bn the 40 minute setting and they came out damp 😈 . I have seen mention of a valve mod on the washer dryers, is there a reason it was changed?? This call has me absolutely baffled. 😥
    Tony
    #361521
    It is listed as a valve and dispenser top assy, part No: C00118578. This will fit both the early and later types.
    Restrictors have never been available as spares.
