hotpoint wdf740 washer dryer
Home Forums Public Support Forums General Enquiries And Questions hotpoint wdf740 washer dryer
  • #102106
    16brae
    Hello,
    I own a hotpoint wdf740 washer dryer. The dryer is not drying the clothes properly and they are coming out hot, but still wet. I clean the filter at the bottom right hand side of the machine, on a weekly basis. So that is clean. There are no kinks in the exit hose. I took a damp cloth and cleaned the drum and rubber gasket inside the machine and removed the fluff. But it is still not drying properly. Is there a programme I could run on the machine when it is empty to get rid of any residual fluff? Any advice would be appreciated. Thank you.
    #487599
    may not be residual fluff as it may be a valve breakdown
    but if it is fluff someone would need to strip it to clean it
    had lots of blocked condensors
    andyjawa
    Very similar model to my brother`s long suffering machine. Yep that`ll be a condenser blockage problem which is the achillies heel of washer dryers (well, that is one of them!). The condenser chamber is that semi transparent plastic fantastic affair moulding underneath the aluminium heater/fan manifold (which needs to be removed too) that runs around to the rear of the tank and is not consumer friendly to remove and clean out and if you refit it badly you get a leak / flood with the pcboard very close by so any cock-ups can be a nuked machine. If your are unsure what the devil I`m on about Google this part number C00255440 (based on your info – there maybe several designs based on the serial codes – but which should at least produce a picture. Anyway, under normal circumstances you never need to buy a replacement you just simply wash them out. If you get that far ( and I really would advise, as per does Dave, that a technician sorts you out thus saving a watery disaster) do not forget to clean the moulding`s dryer metal disc lint filter (C00143949) that gets its tiny holes blocked up too of course.
    #487601
    16brae
    Thank you for your help.
