Looking for advice. When investigating a problem with my belt, I found the wheel had dropped off due to the bolt holding it to the drum having sheared off. Is this repairable or would I be as well buying a replacement washer dryer
electrofix wrote:if the old bolt can be removed then it may be possible to fit a new bolt and pulley if its needed
Thanks Dave, the head has sheared off but there is enough of the bolt to grip onto. Would you advise to use a blow torch to loosen the threads (they seem solid) and then reapply loctite when installing the new bolt?
