hotpoint wdl520
  • #43388
    hilly
    this washer/dryer is about 3 months old intermittently all the lights across the bottom flash and the only way to stop it is to turn off at the socket??
    also i had to replace the dryer heating element about a month ago and now they are saying i dosent dry properly, the sump is clear and thers no duct its straight into the drum everthing seems to be working as it should in thinking they may be overloading it, its used by 8 students,
    any pointers
    thanks paul
    #277087
    maltheviking
    Re: hotpoint wdl520
    How come you got involved with this one Paul? must be under gtee. at 3 months
    #277088
    smartin
    Re: hotpoint wdl520
    sounds like its telling you a fault code make a note of what lights are flashing and repost, i would hazard a guess at it being f-15
    #277089
    hilly
    Re: hotpoint wdl520
    maltheviking wrote:How come you got involved with this one Paul? must be under gtee. at 3 months
    the machine is owned by the university & the use the machines get on the campus they aint interested in gtee’s they class it as commercial.
    all four of the lights flash & the start/pause button, are the error codes on these the same as widl range?
    cheers paul
    #277090
    helo_75
    no, the fault dianosis reads bottom to top, instead of top to bottom, jims added the new fault codes (known error codes)
