Hotpoint WDL520
  • #56631
    jason1970
    Evening gents.
    Got an F10 fault on above machine, ‘pressure switch not sensing’ is F10. Have tried new pressure switch, after checking for blocked pressure chamber and holes/split in pressure tube. Still get the same fault intermitently. Normally within 10 minutes of starting the programme. Any other ideas? (The machine seems to fill for a few seconds at random intervals for a few seconds prior to the machine going in to the error state?)
    Cheers!
    #328183
    A1_Domestics
    Re: Hotpoint WDL520
    Frayed wiring to pressure pipe?
    #328184
    helo_75
    without being clever
    you are reading the fault codes the right way up, arent you?
    either way, its bound to be a pcb issue im sure
    #328185
    Allsorts
    Re: Hotpoint WDL520
    Check the cables from the pcb to the prssure swich for breaks/continiuity
    George
    #328186
    jason1970
    Re: Hotpoint WDL520
    Helo_75, I think so!!!!!! Gents, good advice about the cables. If the fault returns I’ll have a very good look at the loom. Thanks for your help!
