Hello folks.
Need to find out the error code for Hotpoint WDL520.
Top rinse light flashing bottom door lock light solid nothing else flashing. 6 lights altogether Fills for 5 seconds then times out to above error code. I know its in the error code section but I need some guidance to work it out.
Many thanks
It’s logical for it to be the fill valve because it fills briefly pumps out a bit and when it should fill from the other valve it just sits there.
Just wanted confirmation of the error code so thank you very much. But I’m not sure how you did it. :rtm:
