Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WDL520P
- This topic has 11 replies, 4 voices, and was last updated 13 years ago by
Specialist01269.
March 14, 2013 at 7:42 pm #74579
Specialist01269
ParticipantHi Guys: Got a problem with 1 of these machines, it’s just popped it’s 3rd dry element. 1st 1 lasted 18 months from new, second 1 lasted about 13 months & I replaced that in January (Genuine from Hotpoint). She rang me earlier to say her electric had tripped so I went over as it’s only across the road, she’d been using the dryer & it tripped the mains again. Pulled the lid off & once again the element is O/C. Can’t find any blockages in the duct, only thing I can put it down to is the fact that the machine is in a small alcove so not getting enough air circulation. Glad to hear any other suggestions (Clean) 🙂
Andy
March 14, 2013 at 7:57 pm #392102iadom
ModeratorRe: Hotpoint WDL520P
The condenser drying system is totally enclosed so ventilation is not a problem, poor quality gen or non gen elements are though. 😥
March 14, 2013 at 8:10 pm #392103Specialist01269
ParticipantRe: Hotpoint WDL520P
Hi Jim: Cheers mate, :eeek: must have been having another Blond moment when I said that :lol:. Think i’m going to fit a pattern part this time & see what happens, too bloody expensive to fit another genuine 1.
AndyMarch 14, 2013 at 9:07 pm #392104iadom
Whenever I have to take the heater box off on one of these I always cut out the fine mesh from the filter at the back.
March 14, 2013 at 10:00 pm #392105Specialist01269
Thanks for the tip mate, will do that when I replace the element. Luckily i’ve got a pattern 1 in stock so my be able to fit it in tomorrow.
Andy
March 14, 2013 at 10:15 pm #392106Allsorts
Check the fan speed too
March 14, 2013 at 11:12 pm #392107iadom
Allsorts wrote:Check the fan speed too
How do you do that George?
When in situ you can only see the small end of the motor shaft, you can just about make out that it is moving let alone tell how fast it is going.
Do you run it with the heater box opened up to check the speed?
Serious question BTW, interested to know the answer. 8)
March 14, 2013 at 11:56 pm #392108Allsorts
The airflow through the box
George
March 15, 2013 at 8:36 am #392109iadom
I’ll be perfectly honest, I have seen several fans blocked or jammed but can’t say that I have ever seen one running slow?
March 15, 2013 at 11:21 am #392110Specialist01269
Allsorts wrote:The airflow through the box
George
Hi George: Thanks mate, airflow is fine. Duct is clean but as suggested will remove the filter screen anyway.
March 16, 2013 at 7:28 am #392111johnnyj
I seem to recall something about changing the heat deflector as some of them were coming into contact with the element causing a hot spot on the element and causing them to blow. JJ
March 21, 2013 at 3:58 pm #392112Specialist01269
Just to finish this off: Thanks to everyone for their suggestions, but Jim was spot on. The filter mesh was totally blocked, I’ve got to admit I completely forgot to check the screen when I installed the replacement element 🙁 . Thanks Jim.
