Hotpoint WDL520P(UK)C Motor
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint WDL520P(UK)C Motor
Viewing 15 posts - 1 through 15 (of 15 total)
  • #99394
    Twoten
    I am trying to find the part number for a motor for a Hotpoint WDL520P(UK)C 805101363 S.No:601819011363.
    Connect have identified the motor as a MERC00518156 but this is incorrect. The original is a Nidec Sole as the part suggested but the replacement doesn’t fit. The original is a square shape motor whereas the one supplied by Connect is round and the front of the casing catches on the bottom of the tub so won’t go back on the fixings.
    The original is 14000RPM 440W 2A and the replacement 12500RPM 400w 1.9A.
    Connect have double-checked this on the Hotpoint website and still say the one supplied is it’s correct.
    Does anyone have any alternative information please?
    #476186
    don
    Just checked Hotpoint B2B trade spares for your model version it’s C00141663
    Don
    #476187
    Twoten
    don wrote:Just checked Hotpoint B2B trade spares for your model version it’s C00141663
    Don
    If I put that number into https://parts.indesit.co.uk I get the message “This part C00141663 has been superseded by part C00518156” which is the number Connect gave me. Interestingly though, the image on the indesit site matches the original motor
    The MERC00518156 received from Connect had the correct Hotpoint part number on it so not an error by Connect.
    It looks like the type of motor varies depending on where you look. ukwhitegoods shows the round type.
    #476188
    murv
    Have had the front edge of original Sole and late Nidec motors scuff against the the drum during installation but so far they have all slid onto the mounts, sometimes with a bit of force.
    Motor rating plates vary by manufacturer and rarely specify the maximum speed.
    Murv…
    #476189
    Twoten
    murv wrote:Have had the front edge of original Sole and late Nidec motors scuff against the the drum during installation but so far they have all slid onto the mounts, sometimes with a bit of force.
    Murv…
    This would have needed a lot of force and even then I wasn’t sure it would go.
    As it didn’t look or feel right I assumed it was the wrong motor.
    #476190
    i am finding the commercial code does not match
    there are 5 commercial codes linked to this model and all start 8064657????
    looking at a few of them i am getting another motor number apart from the one you found
    Twoten
    electrofix wrote:i am finding the commercial code does not match
    There’s an I.C. W80646570197
    #476192
    murv
    I discounted the C00254768 (3 leg motor) as it is not listed on factory code 80 models built in Comunanza Italy.
    As far as I am aware it only fits the Kinmel Park produced model (WDL520PUK.K) fitted with a screwed WMA type drum.
    Murv…
    #476193
    if that number is wrong and really ends 0097 then above motor numbers are correct
    if your code is correct then its linked to model WDL520PUKC58 and the motor on that one is C00505422
    murv
    Well done Dave, too new for my information.
    A new one fitted with the Whirlpool 58L tank. These usually do not have the 58 suffix on the model label which is most unhelpful.
    Murv…
    #476195
    murv wrote:Well done Dave, too new for my information.
    Murv…
    take it you dont get your info from a hotpoint site othwise you would have found the same info as i did.
    your Hotpoint product knowledge is well above mine lol
    Twoten
    Dave[/QUOTE
    Thanks Dave,
    The image shows full details of the machine. Looking at the image on the Hotpoint website I think this is correct.
    #476197
    yep commercial code is correct so i think you have the wrong motor
    Twoten
    electrofix wrote:yep commercial code is correct so i think you have the wrong motor
    Thanks Dave, looks like it’s in stock with Hotpoint so will get one on order.
    Thanks everyone for the help/advice, much appreciated.
    #476199
    murv
    Oh, I don’t know about that Dave. I only have experience of a very limited range of products & components. Much of my data these days comes from reverse engineering or sifting out and storing relevant information others have published on the web.
    I have not had direct access to servicenet or any trade info for a number of years now. The stuff I work on for local traders is usually quite old so I am often stuck in a time warp when reading about the latest models.
    Murv…
