hi, the machine works perfectly but after it finishes a program
it will not switch on again without disconnecting it from the mains, I have replaced the main arcadia type board from emw twice and its still the same.
I checked both heaters and motor and wiring and all is ok,
Amy ideas welcomed.
What is the ser no as after 106******* if it has only got 4 wires in the harness from the main pcb to the console module it will have to be changed to a 5 way harness when the module is changed as it will work once then not switch back on part no C00271414, jj
Put the original con and display on swapped the 4 wire cable for a 5 wire cable and the customer says it’s working perfectly.
Thanks for the assist on this one no way I could have fixed it otherwise 😀
