Hi, Has anyone the part number for dryer ntc. Arcadia type machine with ntc situated at the front of dryer manifold. Customer saying all leds were fast flashing after ten minutes on wash and dryer cyles. Have come up with C00264605 with no stock at Connect. Not entirely sure if this is right part number.
They have changed to differant part due to that one causing so many problems, have you checked the dryer element had a few of these or the wiring breaking causing these faults also.
Just concluding this one. NTC had a very slight insulation fault caused by damp entering the cap. Fitted direct replacement with plenty of heat silicone to reduce a repeat occurrence. All good 😀
