hotpoint wdl5490
  • #79910
    dopper
    pump goes for 2 secs then off it fills washes spins but pump off after 2 secs then all lights flashing, fitted a board from emw does the same pump is ok anyone help?
    dop
    #411003
    Re: hotpoint wdl5490
    Are you sure that ALL lights are flashing, error codes are all lights along the bottom flashing and a combination of the lower five vertical lights on steady.
    #411004
    dopper
    the 5 lights along the bottom are flashing and the spin and dryer and lock lights are solid lit, is that a code ?
    #411005
    Yes and they are in the error codes thread. 😉
    #411006
    Criscold
    Have you checked Dryer & Heater NTC’s for insulation faults or Poss open or short circuit, I had one that turned out to be the dryer NTC that caused this problem for me.
    #411007
    dopper
    checked dryer ntc that is ok will check the other
    #411008
    dopper
    that one ok as well
    #411009
    dopper
    looked at codes coming up as f13 which is srange as them parts are ok!
    #411010
    dopper
    was about to give up on it so i put old board back on as knew it was ok thought i will nip the plugs and its working ok now what a pile off shit these are
