Hotpoint WDL5490 not draining
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WDL5490 not draining
  • #73595
    boselecta
    Hotpoint washer dryer not draining.
    Getting 0V to drain pump.
    I sent the module to EMW who said they have tested it and its ok and that the pump only operates when there is water in the drum.
    I have tested the machine with water, the pressure switch opperates when filling yet the drain pump gets 0V and does not come on.
    Any ideas or am I going to have to pass this one to Hotpoint?
    thanks
    #388102
    Criscold
    Re: Hotpoint WDL5490 not draining
    Have you checked Dryer & Heater NTC for insulation faults or Poss open circuit as this can cause no pump fault
    #388103
    madangler1
    Is the door locking ok ? Brushes good ? If there is an issue with motor/motor wiring it will prevent pump kickig in.
