Home › Forums › General Trade Forum › Hotpoint WDL756P IC 80858750195 washer dryer lights flashing
- This topic has 10 replies, 3 voices, and was last updated 2 years ago by
neilbow.
March 28, 2024 at 11:05 am #102678
neilbow
ParticipantMorning folks,
Can someone kindly point me in the right direction I have a customers Hotpoint WDL756P IC 80858750195 washer dryer that goes through the wash cycle and the dry cycle but at the end the super wash,extra rinse,reduced creases,slow spin, lights are flashing and the spin light and dry light are solid. ???
Best Regards
NeilMarch 28, 2024 at 7:09 pm #489994electrofix
Moderatorits the solid lights that matter
cant decide if vits fault 6 or 12
both dont seem to fit symptoms
Have gt a manual for WDL540 and fault 6 is not used on that one
fault 6 is door lock problems and fault 12 is board communication
think its more likely to be F12 so I would check the wires and connections between the 2 boards
March 30, 2024 at 12:00 am #489995stratfordgirl
ParticipantI’m pretty sure it’s F06, therefore a door lock fault – either won’t open or won’t close – check lock, wiring and pcb, though as Dave says, not obviously backed up by the symptoms.
April 16, 2024 at 9:22 am #489996neilbow
ParticipantHi everyone, just an update on this issue, the appliance works fine on wash it is just on the drying cycle that it throws up this error code, it goes through the heating cycle, occasionally spinning, condenser valve working and drain pump all working, any thoughts anybody.
Regards
NeilApril 16, 2024 at 9:26 am #489997electrofix
Moderatorget it hot and check dryer elements for earth faults
thats what i would try
April 16, 2024 at 5:06 pm #489998stratfordgirl
ParticipantI’d second that – low insulation resistance of dryer element when hot is likely playing havoc with the electronic control and on-board diagnostics
April 17, 2024 at 8:57 am #489999neilbow
ParticipantHi, I have already done an insulation test on the dryer element hot when it aborts the drying cycle and it checked out fine.
April 17, 2024 at 10:24 am #490000stratfordgirl
ParticipantDoes it dry the clothes?
April 17, 2024 at 5:04 pm #490001neilbow
ParticipantPartially, but not fully
April 17, 2024 at 6:20 pm #490002stratfordgirl
ParticipantIt might be worth checking the dryer fluff filter – these are very prone to blocking up if its the type I’m thinking of. I have seen a blocked dryer filter cause interruption of the drying cycle on a similar Hotpoint model, with a fault code displayed (though I can’t remember which).
April 26, 2024 at 7:31 am #490003neilbow
just an update on this issue, yes Stratfordgirl was correct I pulled off the condenser box and the filter in the rear of the tub was partially blocked, why this throws up this error code is beyond me, AND why they put a filter where it cannot be easily accessed as it is always going to block up is also beyond me.
Many Thanks everyone. Neil -
