Getting e16 code which indicates overfill but the level looks fine.Pressure vessel and hose were clear .The switch clicked on and off ok[single level] is it likely to be the p/switch or a board fault.
i’ve had an earth fault on the heater show up strange faults on these models before, so might be worth checking. have you tried setting program and blowing into the p/switch to see if it sets?
