Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WDPG9640 Aquarius + restarting rinse cycle
- This topic has 7 replies, 3 voices, and was last updated 8 years, 7 months ago by
Scotgr.
August 19, 2017 at 12:39 pm #91954
Scotgr
ParticipantGood afternoon,
My mum has the washing machine as per title. Recently when it gets to about 8 minutes to go on a big standard cotton cycle it suddenly jumps back to the start of the rinse cycle adding a further 40 mins to the cycle. I think this may be a faulty onboard computer. Does anyone have any ideas why this machine has suddenly started doing this?
Many thanks in advance.
ScottAugust 19, 2017 at 12:55 pm #449825Scotgr
ParticipantRe: Hotpoint WDPG9640 Aquarius + restarting rinse cycle
Might I add I tried an empty 30 minute quick wash and it got to 1 minute then jumped to 15 minutes.
August 19, 2017 at 1:53 pm #4498261totalshambles
Other than a pcboard problem which I don`t think that it is because they do not normally fail that way. It is possible that there is a problem with the dryer element running to earth ( or wash element though more likely to be the dryer element ) even though on the face of it it has nothing to do with the wash/rinse/spin cycles. Turn power off to the machine, remove lid, and pull off both wires off the dryer`s element and make sure if not insulated already that they are – get some electrical tape- you do not want anything suddenly touching something they shouldn`t and going pop, that would be the last straw. Then retry on quick wash and see what happens.Just an idea you could try because elements trickling to earth do not necessarily trip electrics let alone blow fuses but definitely do mess temporarily with the electronics in the pcb.
August 19, 2017 at 4:35 pm #449827iadom
ModeratorRe: Hotpoint WDPG9640 Aquarius + restarting rinse cycle
The dryer ntc is a more common cause of weird faults on these TBH.
August 20, 2017 at 9:18 pm #449828Scotgr
ParticipantHotpoint WDPG9640 Aquarius + Water heater
I posted on Saturday about my mums washing machine. After some fault finding I have discovered that the water element is away. (I have checked it with a multimeter) and ran a 90 wash stopped it and felt the temp of the water it was cold). My problem is I can’t seem to remove the elemen from the bottom of the drum. It comes out about 10mm and then it seems to catch on a 1mm high step all around the rubber seal. Is there a trick to getting this out as it feels absolutely solid.
PS sorry for the new topic if this is an issue please merge.
August 20, 2017 at 10:18 pm #449829iadom
No trick, just perseverance.
A thin, flat bladed screwdriver is the best thing to use, you need to gently prise the rubber grommet out as best you can. Sometimes completely removing the temp sensor will allow you to get a screwdriver into the rubber to help to get it moving.
August 20, 2017 at 10:21 pm #449830Scotgr
Thanks for the response I will try on Tuesday to wriggle it out.
August 22, 2017 at 7:45 pm #449831Scotgr
Thanks for all the help. Element changed and it seems to be working fine now! 🙂
