Hotpoint Weapon of Mass Destruction.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Weapon of Mass Destruction.
  • #60852
    Or perhaps washer of mass destruction. :rolls:
    Model WMD960. 🙂
    The display functions perfectly, all programmes can be selected but when you press start the door locks then nothing, no error codes, zilch. 😥
    Any suggestions?
    Specialist01269
    Re: Hotpoint Weapon of Mass Destruction.
    Where’s your big hammer Jim?
    #343888
    Turbo
    Bound to be the board. Have you had a word with Tony at EMW?
    Could be a job for Hotpoint and the 5yrs Parts Gtee 😥
    Graham
    #343889
    The board is already winging its way to the Barn, Millfield as I type. 😉
    Just wondered if anyone else had seen this. 🙂
    helo_75
    i take it you checked the motor coil?
    #343891
    Yes Rob, until I actually saw the machine I was thinking brushes but checked the ( 3 phase ) motor & heater before I removed the PCB.
    As a matter of interest do the 3 phase motors give the same symptoms as the brush gear motors if they are goosed? I think it is a seven tag motor BTW.
    She did say that she washed a large rug or something and she thinks it flashed up F4 ( pressure switch ) but couldn’t be sure. Pressure switch appeared to be OK and sump was clear.
    gandh1
    not a silly o/of/b issue is it???
    i,e repeat on an empty spin only
    #343893
    Allsorts
    You did try fill valve didn’t you?#
    George
    #343894
    Sorry, should have updated.
    The refurbed PCB from EMW sorted it. 8)
    #343895
    Allsorts wrote:You did try fill valve didn’t you?#
    George
    The fill valve would be unlikely to stop it spinning or draining. 😉
