Hotpoint WF
  • #58917
    Micky 32
    Got a call to one of these that was tripping the switch. I go there disconnect the element and it doesn’t trip. I then reconnect the element and it doesn’t trip but after a minute the “Heater relay” fault code comes on. If i disconnect the element the machine keeps working without the fault code. Has anyone seen a WF type machine give that fault code with a dodgy element?
    #336105
    Re: Hotpoint WF
    Not personally, but trying a new element is preferable to having a PCB fault. 😉
    #336106
    Micky 32
    Re: Hotpoint WF
    Replaced element and cured the fault so worth noting to disconnect the element first or if you have one handy to try before suspecting board.
