Hotpoint WF 000P Washing Machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WF 000P Washing Machine
  • #29796
    WhiteVanMan1
    Strange one this. The machine works fine, but the door won’t unlock at the end of the cycle, unless switched off at the socket. This is even if switched off by the on/off switch. Somehow the interlock is receiving a supply when it shouldn’t be. Any ideas? I suspect module.
    #224751
    Re: Hotpoint WF 000P Washing Machine
    WhiteVanMan1 wrote:Any ideas? I suspect module.
    I wonder is the mains polarity is the wrong way round?
    #224752
    main reversal should not affect if
    i assume the machine does not lock door until you press start
    would assume module failure is a fair diagnosis check for earth leakage just in case
    ring up tony at emw if it is a known fault he will have seen it
    WhiteVanMan1
    Thanks for the replies lads, I will check em out.
