hotpoint WF 220 bearing
  • #51747
    slyp98
    hi all ive a hotpoint aquarius wf 220 36162423 door number , its really noisy on spin and feels rough turning the drum by hand , has anyone replaced bearings on this model ? looking at doing the job myself if its not too bad thanks 🙂
    #309158
    Re: hotpoint WF 220 bearing
    Big fun – not.
    Front off, tub out and spilt, measure shaft at front bearing.
    If it’s 35mm, you can buy a BEARING AND SEAL KIT and if needed, a DRUM SUPPORT.
    If the shaft is 30mm, you can get a BEARING AND SEAL KIT. However, if the shaft shows the slightest signs of damage, you need to replace it and it isn’t a spare part. You’ll need to buy a TUB REAR HALF and a 35MM DRUM SUPPORT.
    Apart from that, it’s out with the sledge hammer and drift.
    slyp98
    cheers penguin , although i wouldnt be afraid of the job it sounds a bit long winded and if something goes wrong there is the m/c on the kitchen floor in bits , which of course herself would be thriled with i may splash out the 300 euro for a new model and take the hotpoint out to the shed for a bit of investigation .thanks for the speedy reply as always top notch fella
