Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › HOTPOINT WF 840P FAULT CODE F08
- This topic has 7 replies, 5 voices, and was last updated 16 years ago by
andy webster.
March 26, 2010 at 9:11 pm #53574
andy webster
ParticipantHiya
i have fault code F08 , now i know its a heater relay issue, but where is the heater relay in the machine, and any ideas how to sort it . Im fast running out of disposable paper overalls.
andy
March 26, 2010 at 9:39 pm #316496Penguin45
ParticipantRe: HOTPOINT WF 840P FAULT CODE F08
Heater relay is integral with the main pcb in the bottom of the machine. It is possible that there is a wiring/continuity issue from the board to the heater, but 19 out of 20, it’s the pcb that’s the culprit.
March 28, 2010 at 4:51 pm #316497andy webster
Ok.. thanks for reply …. i fixed it now. Maybe this is worth putting on the forum for others to read before they buy a new module… i guess mine was a loose connection or something …
i had F08 fault code but i guess its the same fix (ish ) for any fault code , worth trying all the same.
All i did was remove the controll module which was very easy… look at tracks on board, wipe it down and put it back…..
making sure you push all connectors back firmly….. then switch it on and wash … hey presto —— NO FAULT CODES and clean clothes….
make sure you disable the power supply and only attempt this if you feel competant. otherwise get an engineer to do it first.
March 28, 2010 at 7:53 pm #316498helo_75
Participantill give it 2 weeks…..
March 28, 2010 at 11:11 pm #316499Penguin45
Hmmm…. Yup, you’ll be back.
April 1, 2010 at 10:59 pm #316500Micky 32
Penguin45 wrote:Hmmm…. Yup, you’ll be back.
Ditto, came across this myself and 2 weeks later 😆
May 26, 2010 at 5:17 pm #316501andy webster
hmmm.. dont know how long this is but its certainly longer than 2 weeks and still working perfectly…..
andy….not back yet …lol
November 21, 2011 at 11:48 am #316502velasquez
How’s it going now, Andy?
I have a similar problem on an Ariston Margherita CDE12X LVA2000C and am wondering whether to take the plunge and buy a Miele or buy a pack of paper overalls and get stuck in…
Tom
