Hotpoint wf 860p ultima. TEST CYCLE
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint wf 860p ultima. TEST CYCLE
  • #88323
    skids
    Hotpoint WF 860P ultima keeps going into a test cycle every time I try to start a wash cycle. Every part of the test cycle seems to work ok and ends with no error/fault codes. The screen shoes ON as it would do normally. Can anyone help as to why this is happening.
    #437684
    Re: Hotpoint wf 860p ultima. TEST CYCLE
    Does it say Test or Demo?
    To cancel Demo you hold in the On/Off and Start/Cancel buttons together for several seconds, hopefully that may clear Test as well.
    You could also try to unplug from mains for a couple of minutes.
    Test programme should only be accessible by using the special hardware key or company laptop so if you can’t clear it then you may have a corrupted eeprom on the main pcb.
