Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Hotpoint WF Series 30mm Seal
- This topic has 11 replies, 6 voices, and was last updated 18 years, 1 month ago by
Phidom.
February 26, 2008 at 9:00 am #34862
ParticipantI need the part number corresponding to Connect part No. 5031684823406, the seal used for the 30mm drum shaft models. This is a special order on Connect but I want to check if any other suppliers keep it in stock.
February 26, 2008 at 11:15 am #244255iadom
ModeratorRe: Hotpoint WF Series 30mm Seal
I usually order the complete kit, 1604600, not listed by Hotpoint as a separate part.
February 26, 2008 at 11:39 am #244256Phidom
ParticipantRe: Hotpoint WF Series 30mm Seal
Yes, so do I but I’m trying to use up some bearings from obsolete bearing kits. Connect are expensive for the complete kit but everyone else I’ve tried is out of stock. 🙁
February 26, 2008 at 12:44 pm #244257Martin
Clean up the old seal enough to read the numbers, then take it along to your local bearing stockist (see Yellow Pages) as they carry loads I expect? 💡
February 26, 2008 at 2:47 pm #244258Phidom
Have ordered a kit plus a couple of seals so at least I will have them eventually. Incidentally, I thought the kit from Connect was expensive at £20.18 until I looked at the Maddocks site where it’s listed at £29.27 😯
February 26, 2008 at 5:02 pm #244259iadom
£3.00 less at Masterpart. 😉 ex vat of course.
March 1, 2008 at 9:30 am #244260Phidom
Martin wrote:Clean up the old seal enough to read the numbers, then take it along to your local bearing stockist (see Yellow Pages) as they carry loads I expect? 💡
It is quite an unusual looking seal, probably specially made for Hotpoint.
March 1, 2008 at 10:13 am #244261bazza500
That connect part no. converts to 026307
April 11, 2008 at 10:39 am #244262Phidom
These seals arrived today but now I don’t know if they have sent me the wrong thing or they are correct but are not a washing machine part at all. They are just rubber grommets such as you would find in a vacuum cleaner. The part is called “Seal for drum shaft 30mm” MER026307. 😕
April 11, 2008 at 4:11 pm #244263Martin114
Sounds like they sent you the old type “Skirt Seal” that used to meet up with the stainless steel washer on the cast bearing spider
April 15, 2008 at 9:03 pm #244264Phidom
I did try to get a suitable seal in Elgin today. I have another of these machines to do and I don’t have a spare 30mm shaft bearing kit. This time the front bearing came out intact so I think the centre section of the old seal assembly could be re-used. The outer part could well be an off-the-shelf seal as suggested by Martin. Unfortunately I’m told there is nowhere in Elgin so my nearest bearing stockist is Aberdeen, 60 miles away.
April 15, 2008 at 9:10 pm #244265aqualectric
Doesn’t look like Qualtex have stock either……..
Steve.
