hotpoint wf000
Viewing 15 posts - 1 through 15 (of 26 total)
  • #31674
    fasetester
    hi guys have to look at a hotpoint washing machine today model wf000 the problum is not bringing in enought water. and the drum not turning would these two thing be related. thanks fasetester 🙂
    #232024
    fasetester
    hi guys went to machine broken belt could any of you guys tel me how the lid come off this machine. when you remove the 2 screws at the back it will not pull off or slide back. thanks fasetester 😕
    #232025
    Re: hotpoint wf000
    Once the screws are removed, push the lid from the front (towards the rear) with the palm of your hand. 😉
    #232026
    fasetester
    Re: hotpoint wf000
    thanks martin for your reply pushed even tapped with the palm of my hands. will not budge never had this problum fasetester.
    #232027
    grendel
    Re: hotpoint wf000
    lift lid from back as best as poss then smack it hard with the heel of your hand at the front left and right hand sides, they can be a bugger but they will give… 😀
    #232028
    Re: hotpoint wf000
    Well it’s more of a very sharp push required, perhaps with both palms?
    Only need to push it back a fraction to clear the front plastic lugs from the fascia panel. Then it just lifts off!
    #232029
    maltheviking
    Re: hotpoint wf000
    Then have the super glue ready to put the bits of plastic back on that break off 😥
    #232030
    cessna
    Re: hotpoint wf000
    grendel wrote:lift lid from back as best as poss then smack it hard with the heel of your hand at the front left and right hand sides, they can be a bugger but they will give… 😀
    I work for them and as Grendel says just give it a smack i usually do it in the centre with one hand.
    Not normally a problem on washing machines it’s the tumble dryers that can be the difficult ones.
    Don’t worry you wont break anything.
    #232031
    maltheviking
    Re: hotpoint wf000
    Have done 😳 you know these Vikings, don’t know their own strength :rotl:
    #232032
    Re: hotpoint wf000
    Smack it with the heel of your hand, Mal – not the double-headed axe…….
    maltheviking
    Re: hotpoint wf000
    Penguin45 wrote:Smack it with the heel of your hand, Mal – not the double-headed axe…….
    Doh
    #232034
    fasetester
    Re: hotpoint wf000
    thanks guys for all your help is there a differience in the belts for this machine. what is the product no for this belt looks like a bit of a dog to get the belt on any tips would it be possible to fit the belt round the drum from under neath the top weight seems to cover the fly wheel as i dont fany breaking the top is this the right number for this belt no1158/456j thanks fasetester.
    #232035
    Re: hotpoint wf000
    The belt part no = 1603287
    I guess you’ve done a few WMA belt changes?….They are just the same!
    In situ Hotpoint supply a belt fitting tool. Without one its a bugger but strong cable ties strapped to the drum pulley is the way forward. 😉
    #232036
    Steven
    Re: hotpoint wf000
    To remove most of the new type lids with the large tabs, after removing screws use a large flat head screwdriver inbetween the frame and tab a gently lever each side, They dont break honest, Ive done a few like this with no problems, at least it saves bruising your palms.
    Steven
    #232037
    Re: hotpoint wf000
    I guess our Northern palms are made of stronger stuff, 😛 😆
    I always use the sharp rap with the heels of both hands, never fails.
