put w/m on spin and mini load light started flashing.so i replaced door lock . no joy f17/f1 fault still coming up so tested motor separately,no problem with motor spins away fine.opened pcb look’s mint also changed harness from pcb to motor and pump. the pump is working fine also :rolls: ❓
