hotpoint wf220 filling when off
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wf220 filling when off
  • #69920
    andysam
    been to this machine and sump hose is at the right height so water is not coming back from sink. when left overnight it fills with clean water could itc be the inlet valves? causing this. if so what part number do i need ta.
    #376441
    Re: hotpoint wf220 filling when off
    Move to correct forum.
    I assume you mean drain hose, not sump hose?
    The part you will need to order is almost certainly a fill valve, you just need to find out which valve now.
    #376442
    DrDill
    andysam wrote:been to this machine and sump hose is at the right height so water is not coming back from sink. when left overnight it fills with clean water could itc be the inlet valves? causing this. if so what part number do i need ta.
    I cant believe some one needs help with this fault and is an engineer?? or am i missing something?
    #376443
    robbra
    +1 and should it be in trade enquiries not in the Rumour Mill?
    #376444
    :clown: was just about to move it correctly, fat finger on the iPad syndrome the first time I moved it. 😆
    As for Dr Dill and robbra’s posts, I couldn’t possibly comment. 😉
    #376445
    robbra
    iadom wrote::clown: was just about to move it correctly, fat finger on the iPad syndrome the first time I moved it. 😆
    Love it 😆
