Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint wf220 power flashing fast
- This topic has 7 replies, 2 voices, and was last updated 13 years, 3 months ago by
chippy1970.
December 13, 2012 at 8:12 pm #73059
chippy1970
Participantmy wf220 broke the other week, on opening i found the left hand hanging spring had snapped. ive picked up a new spring and fitted it. on the first test run after the fix it started ok then after awhile it stopped and now the power button is flashing very fast and the rinse hold is flashing too.
anyone know what the problem could be ?
December 13, 2012 at 8:38 pm #386303AJC_Dave
ParticipantRe: hotpoint wf220 power flashing fast
Check the motor paying attention to the connector and cables. Sounds like when the spring has broken the motor has taken a knock…Power off before you start!!
December 13, 2012 at 8:42 pm #386304AJC_Dave
Also, have a look at the two thin cables that come out of the front of the motor into the connector block for damage…..
December 13, 2012 at 10:51 pm #386305chippy1970
Ok cheers will do
December 14, 2012 at 10:02 am #386306chippy1970
Just checked can’t see any loose or damaged wires. I took motor right out checked all over it and all seems fine. Cannot see any problems anywhere below the drum.
When you press start it does the door locked and wash light and starts to fill then after a few seconds there’s a click where I’m guessing the motor would normally start. Then as I say rinse hold and power button flash fast and it starts emptying and keeps going even after you can hear there is no water going down the drain.
Is it time for a new machine ?
Shame as I’m quite proud of myself keeping it going. I’ve changed the bearings and the motor brushes in the last couple of years.
December 14, 2012 at 1:22 pm #386307AJC_Dave
Check the wires from the motor connector back to the pcb. Check the edge connector on the pcb is tight.
December 15, 2012 at 10:46 am #386308chippy1970
Yeah checked and all ok. I can see some scraping on the white plastic cover to the PCB , guess it got bashed when the spring snapped and the drum dropped. I’m going to take the motor out again and check it over.
December 23, 2012 at 9:19 pm #386309chippy1970
Scrapped it and ordered a Bosch one. Hope I never see any hotpoint crap ever again.
