Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WF220P control board cable positions
- This topic has 14 replies, 3 voices, and was last updated 14 years, 1 month ago by
ACLectrics.
March 12, 2012 at 6:59 pm #68395
ACLectrics
ParticipantI have replaced the control board of my Hotpoint WF220P. Foolishly I removed the cables before taking note of where they went. I know what an idiot!
The only 2 cables that I have a query over are the ones supplying the heater element. There are 4 positions that they could go and I want to get it right before I power up.Any help would be greatly appreciated.
:boops:
March 12, 2012 at 7:25 pm #370919iadom
ModeratorRe: Hotpoint WF220P control board cable positions
Forum Rules #8 applies. 🙁
If you are in the trade then I suggest you apply for trade access ASAP. 😉March 12, 2012 at 8:10 pm #370920ACLectrics
ParticipantRe: Hotpoint WF220P control board cable positions
I am a domestic electrician, does this allow me trade access?
I can supply an email address if that helps?
alex@aclectrics.co.ukMarch 12, 2012 at 8:44 pm #370921ACLectrics
I’m not after any wiring diagrams or schematics, I just need a picture showing the relavent positions.
The 2 connections that could take these 2 cables are either J3 position 5 & 6 or J4 position 4 & 5.
Many thanks again.
March 13, 2012 at 8:41 am #370922Martin
ACLectrics wrote:The 2 connections that could take these 2 cables are either J3 position 5 & 6
:tup:
March 14, 2012 at 4:08 pm #370923ACLectrics
Many thanks for the information, but now the lights flash on the front of the unit. This was not happening before the pcb was replaced.
The on/off light flashes and there are 4 lights on constantly next to the powder draw.
Where can I find the information on error codes for this machine?
March 14, 2012 at 4:16 pm #370924iadom
Those are not error codes, just a thought, was this a new or refurbished PCB?
What was the reason for changing it in the first place?
March 14, 2012 at 4:22 pm #370925ACLectrics
It was a new board, however I have just noticed that the old board does not have a connection J5, however the new board does.
Have I got the wrong board or has the board been updated?
Machine stopped working just before the end of it’s cycle. The old board was checked and a number of components are burnt / blackened.
March 14, 2012 at 4:24 pm #370926iadom
Where did you buy it from, you are aware that these boards have to be programmed?
March 14, 2012 at 4:27 pm #370927ACLectrics
Purchased from Espares.
No I was not aware that the board needs to be programmed.
I assume I have to get someone in to carry this out?
March 14, 2012 at 4:32 pm #370928iadom
eSpares, :rolls: you probably paid over the odds for it as well. 🙁
The nice man from Indesit will come along and programme it with his laptop, for a modest fee of around £105.00
You can do it yourself by purchasing a ‘one use only’ smart card for £20 and a card reader approx £100.
March 14, 2012 at 4:41 pm #370929ACLectrics
Board cost £118, with no mention of programming!
Sounds like it would be as cheap to buy a new machine?
Do all boards require programming.
Surely they could make them plug and play?
Thanks for your help in this.
March 14, 2012 at 4:59 pm #370930Martin
ACLectrics wrote:Board cost £118, with no mention of programming!
I’ve just checked on eSpares web site and they do say this: –
eSpares wrote:Genuine Spare Part for select Arison, Hotpoint and Indesit washers. Please note that this component does not include the eeprom chip
That is totally misleading information because the module in question does have an eeprom chip embedded within the circuit board. However that ‘eeprom chip’ is blank and needs programming as my colleague has already said.
Curiously, if you bought the module direct from Hotpoint it would cost you just £100. Although they make no mention whatsoever about it requiring programming. And to purchase the spare on-line you have to agree to their ‘terms & conditions’. Refunds on returned spares such as this are subject to those strict terms and circuit boards are unlikely to be acceptable for return and credit.
It’s a bl&&dy minefield out there and no mistake….. :rolls:
March 14, 2012 at 5:00 pm #370931iadom
Some boards are P&P, most require some programming which in the vast majority of cases involves using the buttons and control knobs on the machine to do this.
The Indesit Company are one of the few that have this daft system. 🙁
The irony is that had you sent for them in the first place they would have done the whole job for £105 inc parts. 😥
March 14, 2012 at 5:17 pm #370932ACLectrics
Thanks for your help guys.
An expensive lesson learnt !!!!
