i have a problem with the motor on this machine there is no circuit through the field coils there is a reading through the wires going to the carbons and there is a reading through the taco coil.
a new motor is expensive, i have a motor for a wma machine it looks exactly the same but the connector plug is in a different place.
the wma motor has the connector block pointing out the back of the motor,
the wf has the connector block pointing out the front towards the pulley.
i was very tempted to try it but didnt want to blow the pcb.
so the question is is there anyway it would work.
thanks in advance.
