hotpoint wf240p
  • #25877
    robbo1973
    hi been here today press start the door locked light comes on, door locks fills for a few seconds then door locked light goes out and thats it no fault codes any one had this before thanx.
    #207937
    PGS
    Re: hotpoint wf240p
    maybe just door lock overheating and going open circuit, worth a try.
    #207938
    aqualectric
    Re: hotpoint wf240p
    Most likely its the edge connector to the facia PCB not making a good contact, or the connections are oxidised. Pull off the edge connector plug, pinch it with pliers gently to tighten it, clean the edge connections with some emery paper and refit the plug. I had this a few weeks ago and this method sorted it. 8)
    Hope that helps,
    Steve.
    #207939
    robbo1973
    Re: hotpoint wf240p
    thanx for help lads problem was a broken wire in motor harness.machine would lock light on then off and a quick spurt of water and thats it something to look out for.
