Hotpoint WF250 1500Spin,Lock LED flashes, before Final Spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WF250 1500Spin,Lock LED flashes, before Final Spin
  • #81791
    Busyman
    Can anybody help please ? i have a Hotpoint WF250 1500 Spin.
    After loading and press start the door locks and it will run normally through Prewash, Wash , Rinse and Spin. But then it stops and will not enter the Final Spin phase. That is when the ‘Lock LED starts to flash to signal a problem. I am convinced there is nothing wrong with the lock mechanism. The LED is perhaps being used to signal another failure. If I ask it just to spin (no wash program) it locks the door but just wont start and flashes ‘Lock’ I have checked other posts and suggestions and it seems it might be a brush problem on the motor(?) Perhaps brushes too worn for the current needed for a high speed spin (?)
    Many thanks to anybody who can suggest what to go for .
    Busyman
    #417722
    Re: Hotpoint WF250 1500Spin,Lock LED flashes, before Final S
    If the brushes have never been changed then they are long overdue for replacement.
    Easy enough to check them but the usually stop the motor altogether.
    Could still be a faulty door lock or even the pcb.
    #417723
    Busyman
    Many thanks Iadom. One brush was quite badly burnt and short, the other was reasonable. Changed them ok (BTW getting the motor out was made easier by putting the transport clamp bolts in to lock the whole drum assembly so it did not absorb spanner pressure)
    But alas the new brushes have not solved it. The door lock LED works at initial test, if I select any program the door itself locks, but the door lock indicator does not light. And nothing happens ! Perhaps it is the pcb ? Oh dear ! So the fault indication has changed the door locked light no longer flashes. I cant see how I could have caused this, have only removed the motor and put it back. Many thanks to anybody for any thoughts.
    #417724
    One brush badly worn with the other say half worn is a sure sign of a faulty motor sadly. 🙁
    A strong possibility of pcb damage. 😥
    #417725
    Busyman
    Hi Iadom,
    I dont think it can be the motor because as I reported the machine would properly carry out a wash cycle , Prewash, Wash, rinse and spin but then would not start the final phase (FinalSpin) just sat there with the Lock Light flashing. But obviously the motor was ok even with a dirty brush which I thought might have not been able to carry the higher current needed for fast spin. Alas I was wrong ! Have proved that the door lock switch is good, there is a little solenoid inside which when energised not only causes a little plastic tab to mechanically hold the latch in but the same action makes a signal (or voltage) on a third pin to tell the pcb that the door is locked. I have proved that all this happens, and I know that the door is actually locked when it is supposed to be. So it looks like the pcb is not accepting/seeing the door locked signal so all actions are inhibited including the locked indicator LED.
    I suppose a new pcb would have to be programmed for my exact machine Gulp !! ?? How do I do that ?
    #417726
    Busyman
    To be clear. The machine will not do any program now after refitting the motor. When it first broke it would do a partial program with the locked LED hard on as described in my last email but would get stuck on final spin with lock flashing.
    Current state is that the LED says it is doing a WASH, machine doing nothing, LOCKED LED not on. So it has degenerated since the brush change. New brushes, definitely the correct ones, suppose one brush was open circuit ?? (wire to carbon ? ) never thought of testing that. Rather loath to take the motor out again.
    I have carefully inspected the motor plug for loose wires/damage seemes perfect.
    Many thanks for his thoughts to my faithful reader
    #417727
    You programme a £100 pcb buy first purchasing a £20 smart card and a £100+ card reader .
    Or you could send it to EMW for testing and possible repair.
    If you have suitable test equipment it should be possible yo test the motor but as I have already said, one brush worn far more than the other is a sign of a failing motor.
