Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint WF250G error code F10
- This topic has 10 replies, 3 voices, and was last updated 11 years, 11 months ago by
runcorn2.
May 11, 2014 at 1:39 pm #80628
runcorn2
ParticipantF10 “pressure switch not sensing” my machine has the on/off, the mini load(1) and rinse hold (3) lights flashing indicating F10 fault. With mains switch on, machine switch off and door open these lights start to flash after about 2 minutes, if I close the door the pump starts to run. Sometimes the lights flash and the pump runs during the fill or wash cycle. I have disconnected the electrics from the pressure switch and the same lights still flash with the door open. Can anybody help me?
May 16, 2014 at 8:56 am #413526runcorn2
ParticipantF10 hotpoint update
Re my post Sunday, with on/off switch disconnected but power switched on at socket the pump starts to run. Any help, suggestions would be appreciated.
May 16, 2014 at 1:55 pm #413527iadom
ModeratorRe: hotpoint WF250G error code F10
How can you disconnect the on/off switch, do you mean just switched off?
Sounds very much like a faulty main pcb TBH. 🙁
May 16, 2014 at 5:19 pm #413528runcorn2
ParticipantRe: hotpoint WF250G error code F10
I removed the 5 wire plug from the rear of the circuit board containing the on/off switch, isolating the switch and the other lights on the front panel .
May 16, 2014 at 6:16 pm #413529iadom
That totally isolates the main pcb from the control pcb and proves very little.
Still suspect the main pcb.
May 16, 2014 at 6:52 pm #413530runcorn2
IT MAY HAVE ISOLATED THE MAIN PCB BUT THE PUMP STILL STARTED AFTER ABOUT 2 MINUTES, SO WHAT IS TELLING THE PUMP TO START?
May 16, 2014 at 8:26 pm #413531iadom
Did you read my two previous posts? I have already said twice that the main pcb is likely to be at fault. 😉
PS, THERE IS NO NEED TO SHOUT.
Sent from my iPad using Tapatalk HDMay 17, 2014 at 12:24 am #413532runcorn2
SORRY didn’t mean to shout, had left caps on by accident, I did read your other comments but still don’t understand why the pump runs when the PCB is disconnected (even if the pcb is faulty)
May 17, 2014 at 8:00 am #413533iadom
That pcb at the top is only the control pcb, the main, very expensive, needs programming pcb is in the base at the back.;)
May 18, 2014 at 11:40 am #413534runcorn2
Thanks for help and advice, think its time for a new machine.
May 18, 2014 at 1:35 pm #413535Martin
runcorn2 wrote:Thanks for help and advice, think its time for a new machine.
Good move! :tup: -
