Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WF250P
- This topic has 11 replies, 5 voices, and was last updated 17 years, 11 months ago by
JoanneVerrent.
April 18, 2008 at 5:06 pm #36128
JoanneVerrent
ParticipantI have run this machine on a 95 degree cycle to clean out all the old powder etc. It now will not work , power lights come on you can hear the cold fill start but it then cuts off instantly. I have cleared the drain and the pressure switch tube.I also have water coming to the machine from the mains. Do you think this is a failure of the inlet valve or could it be a sensor issue,cant understand why it would just pack up after the hot wash cycle
April 18, 2008 at 6:04 pm #249676hotpnt
ParticipantRe: Hotpoint WF250P
hi, if you have a component failure, then there should be some falshing lights?
April 18, 2008 at 7:30 pm #249677JoanneVerrent
All the lights come on as normal,the water is just not coming throughwhich is why I thought it must be the inlet valve. The machine will not work on the drain or spin cycles either…..
April 19, 2008 at 11:14 am #249678JoanneVerrent
ParticipantHi ,
anymore thoughts from any one?April 19, 2008 at 1:03 pm #249679stripey
Does the door lock and do you get the door lock light on?
April 19, 2008 at 1:17 pm #249680helo_75
Participantwhat he means, is.. have you checked the brushes in the motor?
April 19, 2008 at 2:41 pm #249681JoanneVerrent
ParticipantThe door locks but the light only comes on briefly doesnt stay on only the wash light stays on. I havnt checked the brushes in the motor. I briefly spoke to an engineer earlier he seemed to think it was a module down near the pump ???
April 19, 2008 at 2:43 pm #249682helo_75
Participantid be checking the brushes, personally
April 19, 2008 at 2:46 pm #249683JoanneVerrent
ParticipantThanks for your advice will get on it now.
April 19, 2008 at 4:51 pm #249684JoanneVerrent
ParticipantThank you very much for your sound advice,I have taken the brushes out and given them a scrape the machine is working again now will get some new brushes on Monday and hopefully all will work well.What a great site this is!
April 19, 2008 at 6:50 pm #249685iadom
ModeratorRe: Hotpoint WF250P
I would strongly advise you not to run the machine under load until you replace the brushes, doing this with worn brushes can easily blow the main PCB.
April 19, 2008 at 10:14 pm #249686JoanneVerrent
ParticipantThanks Jim.
