Hi All,
back again,replaced brushes as advised,machine runs like a dream……but has just decided to keep on spinning at the end of the cycle.
It ran OK for a while just seemed to happen on the D 60 degree wash.
Any ideas?
erm.. just have a quick check round, and make sure theres no other wires been pulled off when you took the motor off.. i.e heater wires 1st
main culprit for that is the pcb
just bare in mind it was fine before you put brushes in, so it could well be that youve pulled a wire off somewhere (we’ve all done it ! )
Had a good look round nothing loose or off, didnt take the motor out to replace the brushes did it insitu.
Just noticed however that the pipe from the sump to the drain pump was twisted I wonder if that was causing an issue……
