My washing machine will not work at all.
I have tried all different programs and the machine will not work.
All the leds light up at ‘cancel’ , if I put it onto pump out (shortest program)after a few minutes the door lock starts flashing, the washer does not function at all. I have changed the door interlock and the door is locked after as it should be although this happened before I changed the door interlock. I have removed the pump check it with a meter and it is alright, I also checked the wiring between the pump and PCB at this point and this reads alright. I am at a loss now, please help.
:rolls:
