Hotpoint wf321
  • #53856
    Gordy29
    any help please.replaced pump old one had burntout winding,s.the new one was a genuine one.pump works ok but now on/off light flashes also washenhance rinse hold and ,mini load. thanks Gordy 29
    #317497
    Andystu
    Re: Hotpoint wf321
    Gordy. Theres a good chance it has burnt out the main Board, I believe this are known as the series 4 board or series 8 Board, at the back. The series 8 usually has a big heat sink on it. Possible that it would show burnt tracks on the board, but not always the case. Try these guys http://www.emwelec.co.uk or you can phone them on 01159652118, tell them Andy Stuart sent you and ask for Lee or Tony. They are normally pretty good at diagnosing the fault if you tell them which lights are flashing and will also be able to supply an exchange if needs be.
    Hope this helps,
    Andystu
    #317498
    Gordy29
    Re: Hotpoint wf321
    thanks Andystu
    #317499
    Re: Hotpoint wf321
    Andystu wrote: They are normally pretty good at diagnosing the fault if you tell them which lights are flashing
    Of course you could always read the Known Error Codes thread to find out what the Error Code might be. 😉
    Always best to give the lights by number from top to bottom or right to left.
    1+3+4 is a pump drain fault. Are you getting power down to the pump, if not then it is likely that the pump burn out has taken out the PCB. A visual check will normally show signs of damage. This machine has a single phase motor so no large heatsink on the PCB.
