Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WF321 Panel Lights Constantly Flicker
- This topic has 7 replies, 8 voices, and was last updated 17 years, 6 months ago by
SteveATY.
September 15, 2008 at 11:55 am #39493
SteveATY
ParticipantOK – Interesting one from this morning,
Went to see a Hotpoint WF321. As soon as mains power is applied pretty much all the LED’s on the panel start flickering / flashing on and off. Flickering is random but continuous. No buttons work – not even the on / off.
Checked the obvious like edge connectors and wiring. Machine looks very low mileage and is owned by an elderly couple who say it is less than 4 years old. Kitchen does not seem damp in the slightest.
I’m obviously fearing the worst and think control module fault. Just wondering if it could be the front panel itself? On this machine the control module is in the rear right base.
Any similar experiences?
Steve.
September 15, 2008 at 12:21 pm #262600hotpnt
ParticipantRe: Hotpoint WF321 Panel Lights Constantly Flicker
hi, seen many of these with led problems, lights flickering or on permanently, would try the top board, usually about 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the times it will cure led problems,
October 14, 2009 at 7:49 pm #262601steveDAS
i got same prob but here is video http://www.youtube.com/watch?v=oP0Imu_pb2A
October 14, 2009 at 9:09 pm #262602bubs
Cured the same problem with a recon main pcb, the guy on the phone said it was a common power supply failure.
GraemeOctober 19, 2009 at 7:25 pm #262603twinspark
main board gone did two to day 😀
October 19, 2009 at 10:20 pm #262604cornwell40
Main PCB from EMW. Did one last week with exact same fault.
TC
October 20, 2009 at 9:17 pm #262605lasty
Had two in the last week . Easy fix !!
Largest in the 3 capacitors on the main board rated 680u – 10v ….
Domed the top so sweated it off and replaced by a farnell item , cost all of 17 pence . Downside is you can only buy them in tens , i can live with that though … 😆December 23, 2009 at 3:48 pm #262606neilsukwg
Lasty
You are a genius!
Replace capacitor as described does indeed cure this common fault
Neil : 😀
